Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Programmingly Turn ON/OFF BaseLayerGroup
2 REPLIES 2
swimming123
835 Views, 2 Replies
In order to create a customed buttom to turn on/off BaseLayerGroup programmingly (instead of click the ckeckbox in the Legend), I use the following methods:
  • create an xml and js file, use invoke script method, here is the js file:
          Fusion.Widget.Image = OpenLayers.Class(Fusion.Widget,
               uiClass: Jx.Button,
           initializeWidget: function(widgetTag)
             this.enable();
        activate: function(turn)
           //var theLegend = Fusion.getWidgetById("Legend");
           //var theMap = Fusion.getWidgetById("Map");
           var currentGroup = document.getElementsByTagName("input");
                   var i = currentGroup.length - 1;
                   alert(i);                        //it alert total input box 125;
                   alert(currentGroup[i]);        //it shows this is an HTML checkbox object
                   alert(currentGroup[i].checked);        //it alert this checkbox is not checked, false
                   currentGroup[i].checked = !(currentGroup[i].checked);
                   alert(currentGroup[i].checked);      //it shows this checkbox is now checked, true
although above alert information shows my function is working, but I check the "Legend", the final checkbox state not change, still unchecked;
  • use the server side code to turn the group on
                String sessionId = Request.QueryString.Get("session");
                String mapName = Request.QueryString.Get("MapName");
                Utility utility = new Utility();
                utility.InitializeWebTier(Request);
                utility.ConnectToServer(sessionId);
                MgSiteConnection siteConnection = utility.GetSiteConnection();
                if (siteConnection == null)
                    Response.Write("fail to get site connection, exit");
                    return;
                MgResourceService resSvc =              (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
                MgMap map = new MgMap();
                map.Open(resSvc, mapName);
                double scale = map.GetViewScale();
                if (scale <= 18000)
                     MgLayerGroup layerGroup = utility.getGroupByName(map, "OrthoImage");
                     layerGroup.LegendLabel = "Ortho Image";
                     layerGroup.SetDisplayInLegend(!layerGroup.IsVisible());
                     layerGroup.SetVisible(!layerGroup.IsVisible());
                     map.Save(resSvc);
                     string refreshMap = "<script type='text/javascript'>RefreshMap()</script>";
                     Page.ClientScript.RegisterStartupScript(this.GetType(), "", refreshMap);
                     if (layer.IsVisible() == true)
                         Response.Write("<br/>&nbsp Artho Photo Image Added.");
                     else
                         Response.Write("<br/>&nbsp Artho Photo Image Removed.");
when the button clicked, above code also shows a message "Artho Photo Image Added." But the reality is not turned on.
Any suggestion for this solution is appreciated.
2 REPLIES 2
This post explains how to do that:
http://adndevblog.typepad.com/infrastructure/2012/04/toggle-visibility-of-layer-in-fusion-does-not-w...
Hope this helps.
Tags (2)
It's not helpful due to the group is BaseLayerGroup. I made it work by changing the FusionSF.js, then compress it and replace the original one.
