Infrastructure Map Server Developer
Member
brokosa
Message 1 of 2 (1,152 Views)
Problem with use of dwgLoadprocedure
1152 Views, 1 Replies
01-19-2011 02:50 AM
i try to load a dwg file with program:
mgr = Autodesk.MapGuide.Studio.Site.SiteManager.GetInstance()
con = mgr.CreateConnection(<url>, <user>, <password>, stat)
loadProc = New Autodesk.MapGuide.Studio.Load.DwgLoadProcedure
loadProc.SourceFiles.Add(<file name>)
loadProc.RootPath = "Library://Test"
loadProc.GenerateLayers = True
loadProc.GenerateMaps = True
loadProc.GenerateSpatialDataSources = True
loadProc.GenerateSymbolLibraries = True
loadProc.LayersFolder = "layer"
loadProc.MapsFolder = "map"
loadProc.Execute(con)
but by execute an exception occured:
Fdo exception : Schema is not set - cannot set the class name.
How can I set Schema?
best regards
Boguslaw
Board Manager
Daniel.Du
Message 2 of 2 (988 Views)
Re: Problem with use of dwgLoadprocedure
07-30-2012 02:00 AM in reply to: brokosa
I would like to draw your attention that DWG is supported on AIMS 2013 without file format conversion or load procedure, so it is not necessary to do this any more. Please refer to this video: docs.autodesk.com/MAP/2013/ENU/map_videos_new_features/Publishing DWG files.html
and Infrastructure Studio help.
Please let us know if you are still blocked by this problem and want to keep working on it.
Daniel Du
Developer Technical Services
Autodesk Developer Network
