i try to load a dwg file with program:
but by execute an exception occured:
Fdo exception : Schema is not set - cannot set the class name.
I would like to draw your attention that DWG is supported on AIMS 2013 without file format conversion or load procedure, so it is not necessary to do this any more. Please refer to this video: docs.autodesk.com/MAP/2013/ENU/map_videos_new_features/Publishing DWG files.html
and Infrastructure Studio help.
Please let us know if you are still blocked by this problem and want to keep working on it.
