Problem with Mapguide 6.0 and printing.
We have two systems that are trying to print to a HP Laser jet 4100N and HP Deskjet 950C. We can print one map out then we get an error that the printer could not be found. If you go to control panel, settings, printers, you can still see both printers and can print a test page just fine. This problem happens when you right click on the map and select print or you go to the file menu and select print. If you do the right click method first and print out a map, then try again you get the error message about the printer cant be found, you still can go to the file menu and print on more map. But if you try again, you get the error message. Once you shut Explore down and restart Explore it will print one job again before it fails to find the printer again.
System Configuration
Windows 98 SE 4.10.2222A
128 MB of RAM
IE 6.0 with SP1 and fixs Q813489; Q330994; Q818529
Cipher strength 128 bit
Product ID: 55736-948-6193072-04146
Any ideas or suggestions would be greatly appreciated.
Jacque
