I'm not able to use the tasks from the "javaviewersample" folder. I've added the line:
JkMount /mapguide2008/javaviewersample/* worker1
to the end of my httpd.conf, and I move the file json.jar into the right folder (..\www\WEB-INF\lib), as the file "readme.txt" told me.I've also imported the package, so now I'm able to see the Sheboygan Layout on my browser (GoogleChrome and/or Firefox), but I cannot use the tasks, like: Query, Theme, FindAddress, etc.I receive this error:
An error occurred at line: 53 in the jsp file: /javaviewersample/query/querymain.jspThe method GetMessage() is undefined for the type MgException
I attach the WHOLE "javaviewersample" folder (because I don't remember where I take it, and it's small), in hope that someone can solve this problem.
I use MGE2011 on WinVista, bundled configuration with Java. But I have the same problem using MGOS version 2.2 on Win7, with Java too.
I precise that all the other samples (like "javasamples") work very well. I really don't know where can be the problem...
Unless there is a mistake in the documentation you are working with 2011 so the jkmount entry in your httpd.conf should also be 2011. You indicated 2008. Was this a typing mistake?
Dave
Ouch! sorry, I've posted here a wrong string (I've taken automatically from the file "readme.txt" joint at the folder "javaviewersample"), but I've written it with the right version of MGE on my httpd.conf.
So I fear that the problem of the "not working samples" is another...
Thanks!
Glad that was just a copy and paste error. If you follow the installation guide that has the step by step instructions for the javaviewersample (this should be copied from your MGE 2011 cd as it may have been updated compared to prior years), it usually works first time.
Can you ensure you started with the latest version and walk through the install steps, it only takes about 15 min.
Dave
I've done as the guide tell me. My problem is just on the "tasks" of the layout, I'm able to see the map, to pan and zoom in it, to work with layers inside. But when I try to use the "tasks" tools up in the task_pane I got always the error from the first post:
I really don't understand how get around this problem...
I'm sorry but my reference installation for validating this is down at the moment. I know there are actually 2 entries to be added to the httpd.conf file. Did you add both of them?
Dave
I've just added 1 row to my httpd.conf file:
For the moment, I've deleted the rows in with there was written "e.GetMessage()" and I put:
catch (MgException e)
out.println("<p><strong>Error:</strong> ");
out.println(e.GetDetails());
out.println("</p>");
Now it works!!
But why the system doesn't recognise the "e.GetMessage()" commands?
(and, anyway, it is important for me???)
Thanks!
