jlloyd wrote:
> Good point. The MGE 2009 service is running under the system account, and it is possible that this account doesn't have permissions on that folder. I run my MG 6.5 service under a specially created account. Is it okay to do this with the 2009 service? I was afraid to change it.
Yes, absolutely. In fact, you will need to do this if you want to
access files (such as images) stored on a network share.
> You mention updating the SDFs outside of Studio. Are you using FME?
Yes. FME does a decent job of creating SDFs; its only limitation being
that you can't select multiple geometry types.
> the automation of SDF creation in Studio is really lacking.
No comment 🙂 Apparently there's an API you can use to set up batch
translations that could run from the command line, but you need an
install of Studio for that and I think you have to compile code. Dave
(or maybe someone else) posted an example of how to do this in these
groups a while back.
> Do you still find SDFs to be better performers than Shape files?
Absolutely. To my understanding there are a few reasons for this. SDF
uses FGF (FDO Geometry Format, also know as Autodesk Geometry Format) to
store geometry, so you save a lot of cycles not having to translate each
geometry into a format MapGuide can use. All of the attribute data is
stored directly with the geometry, so you don't need to read three
(geometry, index, dbf) files just to get the attributes. Things like
spatial context and schema are stored directly in the file and only need
to be read rather than generated. Etc, etc... SDF is basically
MapGuide's (or more accurately FDO's) native format. Apart from
performance, I like them because I only need to deal with one file. You
could even store multiple feature classes per file (I've done this a
bit) but apparently this doesn't perform as well as one class per file.
I haven't actually tested this myself, but the developers say it is,
and their word is law 🙂
https://trac.osgeo.org/mapguide/ticket/265
> I was starting to build a map using the new templates. Glad to see this was added in 2009.
Yeah, me too. The reason we started working with DM Solutions initially
was that the built-in templates were not flexible enough for our needs.
I think it's great that DM and ADSK were able to work together to get
this into MapGuide natively. You can follow its development here if
you're interested:
http://trac.osgeo.org/fusion
Does Enterprise come with documentation for the flexible templates?
We've gone to using the open source version, but may end up going back
to Enterprise if we decide to implement Topobase.
Jason
