Infrastructure Map Server General Discussion
Active Member
0 Kudos
Post 1 of 4
Problem ODBC Oracle on Windows 2008 64btis
1491 Views, 3 Replies
04-12-2012 04:48 AM
Does anybody have an idea how to solve the problem of Infrastructure Mapserver 2013 with FDO ODBC Oracle connection?
"An exception occurred in FDO component. Oracle ODBC Database"
Valued Mentor
74 Kudos
Post 2 of 4
Re: Problem ODBC Oracle on Windows 2008 64btis
06-16-2012 03:20 AM in reply to: ambarboza
if your oracle database is 32 bit, you may have to install the 32 bit client on your MapGuide server
Active Member
0 Kudos
Post 3 of 4
06-20-2012 11:21 AM in reply to: gluckett
I Did, but when I set on:
IIS / Application Pools / mapserver2013 / Adivanced Settings / Enable 32-bit applications = true
The AIMS 2013 does not work.
Valued Mentor
74 Kudos
Post 4 of 4
07-03-2012 07:49 AM in reply to: ambarboza
I wouldn't set IIS to use 32bit access. FDO and IIS are really two different beasts.
If you can't connect to ODBC on 64bit (Access) you need to download the 64bit Runtime for Access for your machine.
http://www.microsoft.com/en-us/download/details.aspx?id=10910
gordon
