Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Problem ODBC Oracle on Windows 2008 64btis
3 REPLIES 3
1721 Views, 3 Replies
Does anybody have an idea how to solve the problem of Infrastructure Mapserver 2013 with FDO ODBC Oracle connection?
"An exception occurred in FDO component. Oracle ODBC Database"
3 REPLIES 3
gluckett
if your oracle database is 32 bit, you may have to install the 32 bit client on your MapGuide server
in reply to: gluckett
I Did, but when I set on:
IIS / Application Pools / mapserver2013 / Adivanced Settings / Enable 32-bit applications = true
The AIMS 2013 does not work.
gluckett
I wouldn't set IIS to use 32bit access. FDO and IIS are really two different beasts.
If you can't connect to ODBC on 64bit (Access) you need to download the 64bit Runtime for Access for your machine.
http://www.microsoft.com/en-us/download/details.aspx?id=10910
gordon
