Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
problem in log on to a mapguide site
6 REPLIES 6
khkraju
1013 Views, 6 Replies
to day i loaded autodesk mapguide studio, when i try to enter, it asked to provide site, user id and password, but its not accepting any site addresses i have given in the column, and i am receiving "the specified site is not valid URL syntax" messages, i gone through the help but unable to find the right site address, please help me in this regard.
6 REPLIES 6
Mathew_Miletic
in reply to: khkraju
Did you install Map Server? 🙂
Jermaine
I installed MapGuide Server, Web Extensions and Studio in that order and I am getting the same error. Is there anything else that can cause this problem?
neplaz
Have you try in your browser to access to MapGuide server with mapAgent or Site Administrator URL ? that's ok ?
If you have an error, check your ApacheMapGuide and MapGuide Server services is running.
sage01
Same problem-
I have finished installing
Mapguide Studio Preview
MapGuide OpenSource, made of:
1. MapGuide Server
2. MapGuide Web extensions - I chose the bunlded, php dev enivornment
I am able to successfully login via browser to http://localhost:8008
But, the question is how do i start using Autodesk Mapguide Studio preview software (Autodesk Mapguide Studio 2007 v 1.0.0.16802)
How do I get started? The Interface has a step 1 FIND DATA, where I am prompted for
1. Site
2. User ID
3. Password
Is there any way to get this to connect my local installation of mapguide open source? I tried site=http://localhost and other variations, even tried port 8008, and various user ids but it never works.
I cant seem to see this in any manual. Is there any help/web page where this info might be found ?
In other words, for people who install MapGuide Open Source and wish to use MapGuide Studio (preview) to edit maps, what is the mapguide site, username, password to use?
See attached screenshot from mapguide studio (free trial preview version)
In your case, it sounds like your site is: http://localhost:8008/mapguide
Default username: Administrator
Default password: admin
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5341560@discussion.autodesk.com...
Same problem-
1. MapGuide Server
prompted for
1. Site
2. Us
er ID
3. Password
password
to use?
sage01
Yay!!
Your suggestion worked !
I have attached a screenshot. Basically once you've logged in the Getting Started page still shows, excep site explorer sidebar actually has something - in my case I have the Sheboygan package from osgeo.org loaded. https://mapguide.osgeo.org/gettingstarted.html
Hopefully google crawls this forum and other users of MapGuide Studio preview + MapGuide Open Source can benefit from your answer to this site/user/password question, as mapguide open source help files do not include this little tip about mapguide studio.
Thanks very much Andy!
