Infrastructure Map Server Developer
Member
amantradev
Message 1 of 1 (119 Views)
Polygon Digitize Issue
119 Views, 0 Replies
07-28-2008 04:00 AM
Hi All,
I am trying to Digitize a polygon and add it to existing Featuresource in mapguide 2009. I could able to digitize the polygon and add it usingFeatureService-->UpdateFeature. But I could not able to see the polygon added to the layer. Anybody please help me where i am doing mistake. Following is the code
string coordData = txtCat.Text;
coordData = coordData.Substring(0, coordData.Length - 1);
Array coord = coordData.Split(',');
for (int i = 0; i < coord.Length - 1; i++)
string xyVal = (string)coord.GetValue(i);
string[] xy = xyVal.Split(' ');
double pX = Convert.ToDouble ( xy.GetValue(0).ToString ());
double pY = Convert.ToDouble(xy.GetValue(1).ToString());
polyData.Add(geomFact.CreateCoordinateXY(pX,pY));
MgUserInformation UserInfo = new MgUserInformation(wsSession);
MgSiteConnection siteConn = new MgSiteConnection();
siteConn.Open(UserInfo);
MgResourceService wsRSService = (MgResourceService)(siteConn.CreateService(MgServiceType.ResourceService));
//MgMappingService wsMap = (MgMappingService)(siteConn.CreateService(MgServiceType.MappingService));
MgFeatureService wsFeatService = (MgFeatureService)(siteConn.CreateService(MgServiceType.FeatureService));
//string mapRes = "Library://India/Hyderabad/Floor_1/Data/WS.FeatureSource";
//MgResourceIdentifier mgMapRes = new MgResourceIdentifier(mapRes);
//map = new MgMap();
//map.Create(wsRSService, mgMapRes, "Floor1_Map");
try
string wsFeatSource = "Library://Australia/Perth/Floor_1/Data/WS.FeatureSource";
MgResourceIdentifier wsRSIdentifier = new MgResourceIdentifier(wsFeatSource);
Boolean featSourceExist = false;
featSourceExist = DoesResourceExist(wsRSIdentifier, wsRSService);
if (featSourceExist)
MgPropertyCollection propColl = new MgPropertyCollection();
MgStringProperty strProp = new MgStringProperty("NAME", "POLY A");
propColl.Add(strProp);
MgWktReaderWriter wkReadWrite = new MgWktReaderWriter();
MgAgfReaderWriter agfReadWrite = new MgAgfReaderWriter();
MgLinearRing pExterior = geomFact.CreateLinearRing(polyData);
MgPolygon newPoly = geomFact.CreatePolygon (pExterior,null);
MgByteReader byteReader = agfReadWrite.Write(newPoly);
propColl.Add (new MgStringProperty ("Test","Test" ));
propColl.Add (new MgGeometryProperty ("SHPGEOM",byteReader));
MgFeatureCommandCollection featCmd = new MgFeatureCommandCollection();
featCmd.Add (new MgInsertFeatures ("Poly",propColl ));
wsFeatService.UpdateFeatures(wsRSIdentifier, featCmd, false);
catch
