Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
PHP page 404 Error
1 REPLY 1
762 Views, 1 Reply
PHP page 404 Error
I have installed Mapguide 2011 server on Windows 2008 R2 64-bit and the Web Extensions on the IIS6 web server on W2003 64-bit using the 64-bit versions of both.  Our application uses a combination of .Net 1 and 2.
Application pools have been used for the different .Net versions with Mapguide using the .Net 2 App Pool.
Try as I might I cannot display any php pages there show 'page not found' (404) errors.
PHP runs from the command line processing a text file to echo some text.  I have tried a test.php file to show phpinfo() in various locations but nothing shows.
One inconsistency I have noticed is that within the IIS GUI manager the .php extensions are registered OK but running ADSUtil show scriptmaps does not return any php mappings.
Any help would be much appreciated
Tags (1)
1 REPLY 1
dswilson
Have you tried a phpinfo() page?
It may be you need to add php to your system path.
Is there any other version of PHP installed?
Dave
