Hi..
Can we send the spatial query inside a url to the server side?
suppose if i want to query a particular feature from a particular layer in a map (WebLayout), can i pass the parameters in the url & post it in the server side to get the zoomed output. If yes can you send the format of the URL pls..
Check out the LINKTOVIEW tool for your taskpane in FUSION. You can pass layers and groups you can turn off and on as well as the Extents of the map as URL pass-through.
