Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
nik.mazreen
502 Views, 1 Reply
overview map
i had problem with my overview map. Here's the situation.
overview map1
figure above showed the map appear on main frame map but not on the overview map
figure below showed the map appear on both main frame & overview map.
overview map 2
The strange part is that for the overview map, i'm using the same coding (which is default given in mapguide). but how come the result not the same for both situation. is there anything do to with the quantity of data loaded? because in the first picture, as u can see, it called out alot of layer compared to the 2nd picture.
is there anyway to fix this problem. i'm not sure whether i asked the question in a right way. but i hope u guys could understand. (*i'm using mapguide 2010).
Thx in advance.
1 REPLY 1
Daniel.Du
in reply to: nik.mazreen
Could you please clarify how you made these two maps ? I cannot image the process (differences ) of them...
Daniel Du
Developer Technical Services
Autodesk Developer Network
