HI All, I am using the Autodesk FDO Provider for Oracle. Somewhere between the 200th and 400th request from the map to the Oracle layer, I get the following "hanging" error.
begin dbms_utility.db_version(:dbver, :dbcomp); end;
This is from the trace logs and it is where the request just stalls. In fact this tirggers a whole heap of requests pinning both Oracle and MapGuide.
There are only a dozen layers, all the Oracle Metadata is correct and indexed.
The Oracle is quite finely tuned.
This only occurs with the Autodesk FDO Provider for Oracle.
