style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Andy Morsell" <
href="mailto:amorsell@spatial*nospam*gis.com">amorsell@spatial*nospam*gis.com>
wrote in message
href="news:5660621@discussion.autodesk.com">news:5660621@discussion.autodesk.com...
I am having some trouble connecting to an Oracle
9.2 database with MGE 2008 via Studio 2008. I have created a system DSN
on Windows Server 2003. I know this DSN works fine with
ColdFusion. If I try to use that DSN to create a MGE data connection, I
enter the username and password and test connection is succesful.
However, pressing the Show Tables button displays nothing and the error log
file yields:
<2007-07-17T11:09:05>
Administrator
Error: An exception occurred in FDO
component.
Datastore
'mydatastorename' does not exist, case may be incorrect or is inaccessible
from current connection.
StackTrace:
MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpDescribeSchemaAsXml.Execute line 107 file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\services\feature\OpDescribeSchemaAsXml.cpp
- MgServerDescribeSchema.DescribeSchema line 500 file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
- MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
- MgFdoConnectionManager.Open line 979 file
c:\build_bond_area\Bond_Nightly\BUILD_41.3\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp An
exception occurred in FDO component.
Datastore 'mydatastorename' does not
exist, case may be incorrect or is inaccessible from current
connection.
I've checked with the case
upper and lower and it doesn't matter. I've also tried using the Connect
to a Database option with the Oracle, Microsoft Oracle and Other types with
correct information in the connection strings. In all cases I get a "An
exception occurred in FDO component RDBMS: No current open database".
This particular user in Oracle has connect, DBA and resource
roles.
Any help would be
appreciated. Thank you.
Andy Morsell,
P.E.
Spatial Integrators, Inc.
href="http://www.SpatialGIS.com">http://www.SpatialGIS.com
