I have two questions but before start, I want to give a short information about myself. I'm software developer and have recently changed my work where I have to learn developing with AIMS 2012. I have no exprience before in that business line. I hope that I can find answers to my questions here.
1. I have develop a simple application which is bringing a image using the Rendering Service according to the given query. I do not show a map to user. Actually I connect to map server and open the my layout but visibility of the frame in which I put my layout is false. So users do not realize that there is weblayout on web page. But I do not want to do that. So my first question is that is there way to get image from map server not having to open a map in web page, for example may be using some services. Simply I want to optain a image not using a weblayout because users do not need to see a map. is it possible?
2. I also need to hide/show features' label programmatically, for example building's name... A piece of code would be realy nice.
thanks in advance
Ferdi
Solved by jackie.ng. Go to Solution.
1. MgMap.Create() your desired Map Definition and send that off to the MgRenderingService for rendering. This doesn't require opening the viewer.
2. Have the labels in a separate Layer Definition, and toggle them programmatically in your MgMap.
- Jackie
