Infrastructure Map Server Developer
New Member
Ferdi_Güler
Message 1 of 3 (1,703 Views)
Optainind a Image not Having to Open a Map
1703 Views, 2 Replies
01-02-2012 11:48 AM
I have two questions but before start, I want to give a short information about myself. I'm software developer and have recently changed my work where I have to learn developing with AIMS 2012. I have no exprience before in that business line. I hope that I can find answers to my questions here.
1. I have develop a simple application which is bringing a image using the Rendering Service according to the given query. I do not show a map to user. Actually I connect to map server and open the my layout but visibility of the frame in which I put my layout is false. So users do not realize that there is weblayout on web page. But I do not want to do that. So my first question is that is there way to get image from map server not having to open a map in web page, for example may be using some services. Simply I want to optain a image not using a weblayout because users do not need to see a map. is it possible?
2. I also need to hide/show features' label programmatically, for example building's name... A piece of code would be realy nice.
thanks in advance
Ferdi
Valued Mentor
jackie.ng
Message 2 of 3 (1,696 Views)
Re: Optainind a Image not Having to Open a Map
01-02-2012 03:47 PM in reply to: Ferdi_Güler
1. MgMap.Create() your desired Map Definition and send that off to the MgRenderingService for rendering. This doesn't require opening the viewer.
2. Have the labels in a separate Layer Definition, and toggle them programmatically in your MgMap.
- Jackie
New Member
Ferdi_Güler
Message 3 of 3 (1,688 Views)
01-03-2012 02:07 PM in reply to: jackie.ng
thanks alot... it realy helped :smileyhappy:
