Show only
Search instead for
I was using the myMap_onDigitzePoint(map, point) function without troubles since now that I've switched the rendering of the ActiveX object to a JS function. I mean, the
Let's note that the VBScript is loaded, I've added an Alert "test" in it and it's showing up properly at page load, so it's just the listener that it's not working.
