Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
onDigitizePoint issues
1 REPLY 1
mdevera
213 Views, 1 Reply
Hi all,
I was using the myMap_onDigitzePoint(map, point) function without troubles since now that I've switched the rendering of the ActiveX object to a JS function. I mean, the declaration is not in the HTML but added on the fly to the DOM.
The VBScript is still in the HTML HEAD tag.
The problem is that the onDigitizePoint function is not rising up since I switched to the JS version of my website.
Could it be that, since the tag is not yet rendered when the VBScript is loaded that the myMap_onDigitizePoint listener is not listening to digitize events?
Thanks in advance,
1 REPLY 1
mdevera
in reply to: mdevera
Let's note that the VBScript is loaded, I've added an Alert "test" in it and it's showing up properly at page load, so it's just the listener that it's not working.
