rolicor2 wrote:
> Thanks Jason, you're right on.
> The Mapguide service is running as Local System. I believe this by default. Using a domain user does work but should it be running as domain user. There's always the possibility of the domain user being inadvertently locked. Will the service have issues then when it happens?
> Thanks again for your reply.
Normally, I get around this by having a special sevice account domain
user set up with restrictive permissions and "password never expires" set.
You could also set up local users on both the file server and the
MapGuide server with the same password, but you run into the same
problem there.
Jason
