I'm using Visual Studio 2010, C# and IIS7 .
I want to develop a test application so I can show a customer that MapGuide Enterprise is a viable product for serving maps and for users to digitise and edit (line, polygons) on the client side.
So far its been an uphill struggle - is anyone out there doing this - are there any good .Net examples with code showing this?
I'm actually a little worried about the lack of responese on the forums etc... (apologies Jackie) I'm starting to get the impression that MapGuide isnt the technology best suited to this.
One the MGE installation media there is a Samples directory. There is a PHP example in there that shows digitizing geometry.
Unfortunately there isn't an equivalent example for .net and Java and I cannot explain why that would be the case. If you know PHP you should be able to convert that sample to .net
- Jackie
