Infrastructure Map Server General Discussion
New Member
0 Kudos
Post 1 of 2
Name Column - Case Sensitivity ?
59 Views, 1 Replies
05-04-2007 07:12 AM
I am looking for a way to theme values in the NAME column of a SDF file. The SDF file was built from multiple drawings - based on the layer name - using AutoCAD Map 3D 2007. Since the layer name is a different "case" in each drawing, MapGuide 6.5 recognizes layer "Test" and themes it as instructed, but not layer "TEST". Can I place a formula in the MapGuide Author to theme these layers as one? Can I place a formula in the MAP2SDF dialog box (in AutoCAD Map) that will enable this NAME column to be all UCASE\strcase?
Member
0 Kudos
Post 2 of 2
Re: Name Column - Case Sensitivity ?
11-20-2008 06:16 AM in reply to: cameron.gartner
Cameron,
Did you ever find a solution to this questions?
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
