Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 7 (716 Views)
MyByteReader to Stream Reader
716 Views, 6 Replies
11-09-2012 01:19 PM
Can I get the data from MgByteReader, and turn to Stream Reader; so I can make a pdf map using iTextSharp?
Valued Mentor
jackie.ng
Message 2 of 7 (705 Views)
Re: MyByteReader to Stream Reader
11-11-2012 06:27 PM in reply to: swimming123
You can try this class I wrote, that provides a System.IO.Stream adapter over the MgByteReader:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Desktop/MapViewer/MgReadOnlyStream.cs
- Jackie
Valued Contributor
swimming123
Message 3 of 7 (690 Views)
11-13-2012 12:20 PM in reply to: jackie.ng
Thank you Jackie,
when I add your class to my project, I found I cannot reference the namespace OSGeo.MapGuide.Viewer; And Line 216 "Strings" not exist in the context. I am pretty new, can you help me more? Thanks again.
Valued Contributor
swimming123
Message 4 of 7 (687 Views)
11-13-2012 05:43 PM in reply to: swimming123
Did I need other assembly class files?
Valued Mentor
jackie.ng
Message 5 of 7 (683 Views)
11-13-2012 06:47 PM in reply to: swimming123
That file can't just be dropped in, so change/rename the namespace
Strings.ErrorStreamNotRewindable is just a localizable message, just replace it with something equivalent
- Jackie
Valued Contributor
swimming123
Message 6 of 7 (680 Views)
11-13-2012 07:13 PM in reply to: swimming123
I create a new class file and paste your code there, but still I cannot new a MgReadOnlyStream. I cannot find the problem is.
Valued Contributor
swimming123
Message 7 of 7 (670 Views)
11-14-2012 07:28 AM in reply to: jackie.ng
Finally I get the MgReadOnlyStream. Thank you Jackie.
