Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
MyByteReader to Stream Reader
6 REPLIES 6
swimming123
987 Views, 6 Replies
Can I get the data from MgByteReader, and turn to Stream Reader; so I can make a pdf map using iTextSharp?
6 REPLIES 6
jackie.ng
in reply to: swimming123
You can try this class I wrote, that provides a System.IO.Stream adapter over the MgByteReader:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Desktop/MapViewer/MgReadOnlyStream.cs
- Jackie
swimming123
in reply to: jackie.ng
Thank you Jackie,
when I add your class to my project, I found I cannot reference the namespace OSGeo.MapGuide.Viewer; And Line 216 "Strings" not exist in the context. I am pretty new, can you help me more? Thanks again.
swimming123
Did I need other assembly class files?
jackie.ng
That file can't just be dropped in, so change/rename the namespace
Strings.ErrorStreamNotRewindable is just a localizable message, just replace it with something equivalent
- Jackie
swimming123
I create a new class file and paste your code there, but still I cannot new a MgReadOnlyStream. I cannot find the problem is.
swimming123
Finally I get the MgReadOnlyStream. Thank you Jackie.
