If I start developing using the Open Source MapGuide version and then later decided to use the Enterprise version can i use the exact same code and setup?
Sure, just make sure you create the MGP file and you update your code to use the correct ini file. It is actually easier moving from OpenSource to Enterprise than the other way around.
