just some notes for improvement and UI fixes for the Mobile Viewer:
- Correct the conflict between Layer or Properties and Map - when trying to scroll though more than 10 layers or 10 properties, the UI conflicts with the Map and the user cannot scroll down very well - it is a battle between the OpenLayers map and the Properties/Layer UI
- The sticky Legend. After toggling the Legend, and then closing it, simply pan the map and the legend re-appears. This little bug is pretty frustrating to the user. Fixed by catching the deactivate event on the Legend close.
- Legend using the Pretty Name rather than acutal name of the layer. For example, if Ihave a group called WINFRA but call it "Water Infrastructure" as the display name, I expect to see that in the legend, not WINFRA for example - this should be true for Columns, Layers and Layer Groups - no one wants to see the ugly names.
This list is just a quick note of what I have seen in 2014 Mobile Viewer so far.
