Infrastructure Map Server Developer
Valued Contributor
swimming123
Message 1 of 2 (1,165 Views)
Mobile viewer Extension for Map Server Infrastructure
1165 Views, 1 Replies
06-26-2012 08:22 AM
When we use the Map Server Infrastructure, Does it matter to select Ajax viewer or Fusion Viewer?  Does Fusion will load normally on a mobile device? How can I make the Mobile viewer extension work? Thank you
ADN Support Specialist
Daniel.Du
Message 2 of 2 (1,089 Views)
Re: Mobile viewer Extension for Map Server Infrastructure
08-27-2012 02:07 AM in reply to: swimming123
For mobile devices, it is recommended to use MobileViewer, which is much lighter than Fusion Viewer, please refer to this blog to check whether it helps or not: http://adndevblog.typepad.com/infrastructure/2012/06/creating-custom-control-for-mobile-viewer-of-ai...
Daniel Du
Developer Technical Services
Autodesk Developer Network
