Hi all,
Recently I try to make a map to be displayed in mobile web. My first question is what coordinate system I can use? Any options? Can I use UTM system or I have to use web mercator?What if I don't include base layers like Bing, OSM? Thank you.
If you're not integrating with OSM/Google/Bing layers then you can use whatever coordinate system you want really.
Otherwise you have you use web mercator if you want the OSM/Google/Bing layer to line up with your map
- Jackie
