Hi, i had problem with my overview map. Here's the situation.
overview map1
figure above showed the map appear on main frame map but not on the overview map
figure below showed the map appear on both main frame & overview map.
overview map 2
Is there anything do to with the number of layers? because in the first picture, as u can see, it called out alot of layer compared to the 2nd picture.is it because of the bugs in MGE 2010. Is there anyway to fix this problem. i'm not sure whether i asked the question in a right way. but i hope u guys could understand. (*i'm using mapguide 2010).
**i did try to play around with min ratio & max ratio as suggested by dswilson, but it does not change anything..
Thx in advance.
I usually play around with the max and min ratio to get this working. you kinda have to play around with the numbers a bit using extremes.
what works best for me is a very small min and a very large max. try 1 and 1000000. i have no idea what it means, but the overview map stays pretty constant.
