Thanks Dave for your prompt help.
Both the MGE SP1 as well as the King Provider for Oracle worked for a while
(1-2 days), and developers tried them out and triggered some errors, then I
had to restart the service or reboot the sys, then this problem occurred.
You are right, I am accessing the Oracle Spatial (9i) database in a foreign
schema not a native FDO one created by Map. In this case we found the King
provider is very good in that it allowes us to access both Spatial tables
and views as it does with MG 6.5, while the Autodesk FDO Provider for FDO
does not allow me to access Spatial views.
Yes, I changed the setting from 60 to 120, but it didn't solve my refresh
problem.
Then, I though some dll files might be corruped, so reinstalled the .net
framework 2.0 and SP1, but the problem remains. I may have to uninstall
/reinstall everything.
Meng
wrote in message news:5398935@discussion.autodesk.com...
On a separate note alltogether, could it be that you edited the registry for
the FASTCGI settings and made the value too small? I know you were looking
at this the other day.
Dave
