I can't see any providers in Studio 2011. The MGE works, admin and \mapagent\index.html works, some request services works but if I try to GetFeatureProviders MGE hangs .
Is any right's need on MGE install folders or any tricks to start ? I choose Apache webserver .
It's very strange becasue the trial version works well but after reinstall the comercial version no works.
Thanks!
Kalmy
have you checked the errors log on the server side? could give you some lead especially if the program hangs.
Also, check your providers.xml (do a search for it, if you dont know where it is). if it doesn't exist or it's empty, though i dont know why it would be, that's probably your problem.
I found an XML providers file in both 2011 Enterprise and Studio FDO folders.
They both appear to contain references to the FDO providers not showing up in Studio.
do you see any errors in the errors log? it should be located in the Logs folder where you installed the server. may give us a clue..
