Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
MGE 2010 - Autodesk Oracle FDO layer not visible at full extents
2 REPLIES 2
jdoherty
599 Views, 2 Replies
I am running MGE Update 1b on Windows Server 2003 and IIS, Oracle 10G R2. I have:
- An SDF Data Source for Country polygones
- An Autodesk Oracle FDO Data Source for lines
- An Autodesk Oracle FDO Data Source for points
- A layer defined for each of the above, coordinate space is LL84
The country polygones show up, but the lines and points from the oracle do not display until I get the zoom/scale to under 1:210,000,000
Anyone run into this type of issue ?
2 REPLIES 2
dswilson
in reply to: jdoherty
I have seen this issue before and believe it to be an Oracle bug. This only happens with Oracle and LL84. Unless there is another variation of the WKT (srid) that could be assigned to the Oracle data I'm not sure how to fix this.
Dave
jdoherty
Anyone have a line on the bug Dave mentioned ?
