Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
MG Studio 2009
3 REPLIES 3
264 Views, 3 Replies
MG Studio 2009
I made a alias for the large raster file, but I cannot find the right place to locate it in Studio 2009.
New > Data Connection > OSGeo FDO Provider for Raster > new feature source tab
If I make SHP connection, in new feature source tab I can click the file button and select alias folder.
Anyone can tell me how to do?
3 REPLIES 3
It is probably using the generic editor interface which I don't think has support for browsing aliased folders.
Nevertheless, if you know what the alias is you should be able to put %MG_ALIAS_PATH[NAME_OF_YOUR_ALIAS]% (I might be wrong about the special variable name here. Might want to double-check) into the raster path and it should work fine.
- Jackie
I tried it and success for testing connection. Can you give me more info I can access the raster file in alias folder?
Thanks in advance.
second screen shot
