Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 5 (697 Views)
Measuring tool in AIMS2013 NOT stop by double click.
697 Views, 4 Replies
11-29-2012 02:16 PM
I found measing tool does't stop by double click. It is annoying bug.
Valued Mentor
jackie.ng
Message 2 of 5 (696 Views)
Re: Measuring tool in AIMS2013 NOT stop by double click.
11-29-2012 06:00 PM in reply to: swimming123
Double click works. I'm guessing it just has a very low tolerance making most double clicks not register
- Jackie
Valued Contributor
swimming123
Message 3 of 5 (694 Views)
11-29-2012 07:28 PM in reply to: jackie.ng
It works on FireFox, not IE for me. I don't know how to fix this if it's because of tolerance. Thank you Jackie.
Active Member
bernhard.maehler
Message 4 of 5 (684 Views)
Betreff: Measuring tool in AIMS2013 NOT stop by double click.
11-30-2012 08:26 AM in reply to: swimming123
Questions:
1) Which version of IE do you use?
2) If IE 9: Are you running IE in Compatibility mode?
3) What is the language of your operating system (OS)?
Things I've noticed:
- Double click works fine in IE 9 (without Compatibility mode), Firefox, Chrome and Safari.
- It doesn't work on IE 7 and IE 8.
- In IE 9 it doesn't work if you have enabled the Compatibility mode.
Also I've noticed that some functions doesn't work proper on a non-English OS.
However (as a workaround) 'SHIFT + left mouse click' works with all browsers (even IE 6).
System: MapGuide Open Source 2.4 as well as AIMS 2013 with Apache on Windows Server 2012 (German OS)
- Bernhard
Valued Contributor
swimming123
Message 5 of 5 (680 Views)
11-30-2012 09:08 AM in reply to: bernhard.maehler
Yes, it works without compatibility mode. Thank you for the information.
