Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Maptip to change into image gallery
4 REPLIES 4
DEVR1930
834 Views, 4 Replies
I am trying to create a Image gallery inside the map. when i click on the MapTip Layers, an image gallery window should popup. Is it possible to activate a hyperlink from Maptip. Please suggest me some ideas. Thank you.
4 REPLIES 4
sroussev
in reply to: DEVR1930
Hey,
I think you can find useful info here:
http://themapguyde.blogspot.com/search?q=tooltips
DEVR1930
in reply to: sroussev
thank u all 🙂
DEVR1930
Is it possible to implement Auto Re-Size Maptip i.e. When the user resizes the map browser window the embedded viewer will also resize and the background of the Viewer should be translucent.And Maptip viewer should cover about 90% of the display map area. i try to edit maptip.js file inside fusion/widget folder. But then i dint get any result when i change the folder.
can a Maptip gallery be implemented by these requirement?
