Infrastructure Map Server Developer
*Daniel, Scott D.
Message 1 of 7 (180 Views)
MapServer.exe Memory Hog NT4 sp6a
180 Views, 6 Replies
01-21-2002 03:49 AM
Has anyone had problems with the MapServer.exe chewing up memory or not
releasing resources? Intalled on NT4 with sp6a. I'm finding it necessary to
reboot the server nearly every week because MapServer.exe is growing in it's
need for memory resources. Is there a fix? Is this an issue with Windows
2000 server?
Scott D. Daniel
GIS Supervisor
Ruekert · Mielke
W233 N2080 Ridgeview Parkway
Waukesha, WI 53188
(262) 542-5733
(262) 542-5631 Fax
sdaniel@ruekert-mielke.com
*Li, Meng
Message 2 of 7 (180 Views)
Re: MapServer.exe Memory Hog NT4 sp6a
01-21-2002 05:55 AM in reply to: *Daniel, Scott D.
Set up a schedule batch process of reboot ing your Win NT each week or each
day is an acceptable workaround. Memory leakage is a Windows old problem.
We use the method.
Meng Li
Scott D. Daniel wrote in message
<8B1B7530250F5D2137504F77C195CDAC@in.WebX.maYIadrTaRb>...
it's
>2000 server?
>Scott D. Daniel
>GIS Supervisor
>Ruekert · Mielke
>Waukesha, WI 53188
>(262) 542-5733
>(262) 542-5631 Fax
*Cardinal, Pierre
Message 3 of 7 (180 Views)
01-21-2002 06:37 AM in reply to: *Daniel, Scott D.
Excerpt from MG603ServicePackReadme.htm
Autodesk MapGuide 6.0.3 - Service Pack Readme
In an effort to continuously improve the quality and stability of our
products, Autodesk® is releasing this Service Pack. We believe that this
update will improve our customers' experience with Autodesk MapGuide®.
This Service Pack includes the following software updates:
Autodesk MapGuide Server (Release 6.0.3.2)
Autodesk MapGuide Provider for Oracle Spatial (Release 6.0.3.2)
Autodesk MapGuide Author (Release 6.0.3.3)
Autodesk MapGuide Viewer ActiveX Control (Release 6.0.3.3)
Autodesk MapGuide Viewer Plug-In (Release 6.0.3.3)
This Service Pack addresses the following issues:
Autodesk MapGuide Server Failing as Memory Usage Climbs
The problem of Autodesk MapGuide Server crashing as memory usage climbs has
been fixed.
Autodesk ©
Pierre Cardinal
"Scott D. Daniel" a écrit dans le message news:
8B1B7530250F5D2137504F77C195CDAC@in.WebX.maYIadrTaRb...
to
it's
> 2000 server?
> Scott D. Daniel
> GIS Supervisor
> Ruekert · Mielke
> Waukesha, WI 53188
> (262) 542-5733
> (262) 542-5631 Fax
*Desai, Manoj
Message 4 of 7 (180 Views)
Re:
01-25-2002 11:32 PM in reply to: *Daniel, Scott D.
I'm not sure how this article helps. I am experiencing this same problem
with nt4.0 and sp6 with mapguide 6 and I just patched with the patch that
came out on the 17th. Is that all I can do?
"Pierre Cardinal" wrote in message
news:A6154E625A56C59882389BF3763C9B04@in.WebX.maYIadrTaRb...
> Hi,
has
> been fixed.
> Autodesk ©
> Pierre Cardinal
news:
> to
> it's
> > 2000 server?
> > Scott D. Daniel
> > GIS Supervisor
> > Ruekert · Mielke
> > Waukesha, WI 53188
> > (262) 542-5733
> > (262) 542-5631 Fax
*Herrera, Daniel
Message 5 of 7 (180 Views)
Re:
03-07-2002 05:32 AM in reply to: *Daniel, Scott D.
Does anybody have any info. on this? This is happening to me MapGuide
Server5 (with applied SP fr. autodesk) on Win2K. Memory is leaking from
dllhost.exe and mapserver.exe runs at 99% CPU a few times a day, which
causes layer access to timeout. Checked the code and it seems fine (no
infinite loops, recordsets, connections closed, etc...) So far memory leak
on dllhost running MG Server 6 does not do this with the same code
(different machine, Win2K). though there are other problems with MG6
preventing me from switching now...Any thoughts?
"Manoj Desai" wrote in message
news:AAC597303D20A5C6447652DE990FA076@in.WebX.maYIadrTaRb...
> > Hi,
> has
> > been fixed.
> > Autodesk ©
> > Pierre Cardinal
> news:
not
necessary
> > to
in
> > it's
Windows
> > > 2000 server?
> > > Scott D. Daniel
> > > GIS Supervisor
> > > Ruekert · Mielke
> > > Waukesha, WI 53188
> > > (262) 542-5733
> > > (262) 542-5631 Fax
New Member
stefanl
Message 6 of 7 (180 Views)
Re:
03-12-2002 12:25 AM in reply to: *Daniel, Scott D.
More Problems:
We are Running Mapguide 5 with SP2 and we have to reboot or kill the mapserver.exe proccess several times a day, because the Map Server Software hangs.
This is not nice as we have a 24 X 7 operation to look after.
Please advise!
*Snapple
Message 7 of 7 (180 Views)
Re:
04-01-2002 12:18 PM in reply to: *Daniel, Scott D.
Hi stefan
By right sp1 of mg6 fix your problem, provided that you can succesfully
installed mg6 sp1. To be frankly I experienced the same thing when virtual
memory reach 75 mb than everything is hang. Can share with me if you can
successfully patch using sp1? I give up mg6 for production and go back to
mg5.
"stefanl" wrote in message
news:f0ae313.4@WebX.maYIadrTaRb...
More Problems:
hangs.
Please advise!
Announcements
Need installation help?
