Infrastructure Map Server Developer
New Member
neeedo7
Message 1 of 2 (343 Views)
MapGuidel 2011 API Cannot Edit, Update or Delete features
343 Views, 1 Replies
05-16-2011 01:19 AM
I have a problem editing features in Mapguide 2011 using the API in C# with asp.net.
The map displays fine in the browser, but  whenever I try to delete or update a parcel, nothing is changed. Also I can’t add a new parcel. No exceptions or errors appear, and I believe the code is also correct.
I referenced all the correct aspx pages in the layout in Mapguide Studio and all 2011 dlls in the application.
I don’t know what’s wrong and why is it that the map doesn’t update or reflect these changes.
Is there something missing that I should configure to Edit the features using Mapguide 2011?
I'm connecting using an anonymous user.
Here's the code for deleting:
  public bool RemoveSelectedParcels(string selectString)
        //Please type in the code between the comments
        MgResourceService resService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
        MgFeatureService featService = (MgFeatureService)siteConnection.CreateService (MgServiceType.FeatureService);
        MgMap map = new MgMap(siteConnection);
        map.Open(resService, "Sheboygan");
        //MgLayer layer = getLayerByName(map, "Parcels");
        MgLayer layer = map.GetLayers().GetItem("Parcels") as MgLayer;
        MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
        commands.Add(new MgDeleteFeatures("Parcels", selectString));
        MgResourceIdentifier resId = new MgResourceIdentifier("Library://Exercise/Data/Parcels.FeatureSource");
        featService.UpdateFeatures(resId, commands, false);
    return true;
Attached is the Exercise that I was trying to implement. It was originally done using Mapguide 2007.
But I'm trying to implement it on Mapguide 2011.
Valued Mentor
jackie.ng
Message 2 of 2 (308 Views)
Re: MapGuidel 2011 API Cannot Edit, Update or Delete features
06-15-2011 10:19 PM in reply to: neeedo7
Firstly, try the code with an Administrator login. If that works then it's because generally speaking, Anonymous users are denied write acess to Library-based resources, and denied access to write features to Library-based feature sources. This is because Anonymous is the lowest privilege MapGuide user account.
- Jackie
