Hi guys,
I developed an application that take a .dwg file and convert into weblayout. But when I converted the VISIO file into .dwg and import that dwg into my application is not creating the weblayout. Even I try in Mapguide studio2007, it shows the msg that this file is not licensed by autodesk. Pls help me out or give me the work around of this problem.
I attached the .dwg file pls try to import on mapguide studio and see the result
Its very urgent
