Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
MapGuide Server Goes Down Often
5 REPLIES 5
1450 Views, 5 Replies
Hi
MapGuide Server goes down often when there is even more than 2 client web browser access, can any load balancing patch or anything can be applied to solve this?
5 REPLIES 5
Daniel.Du
Which version are you using? Are you using any custom application when you run into this problem?
Daniel Du
Developer Technical Services
Autodesk Developer Network
emluv
in reply to: Daniel.Du
Daniel,
Do you know of any reason this could be happening? I am having the same issue, however, I do not know if it is becase of 2 users accessing the map. I am using a Mapguide Enterprise 2011 Fusion layout and the server is installed on Windows 2008 R2. We do have some custom ColdFusion applications running with the map, not sure if this is the issue. Any insight would be greatly appreciated, I am constantly having to reboot the server in order to get the map working again.
Thanks!
Emily
emluv
Daniel.Du
in reply to: emluv
Hi Emily,
If you are using custom code, I'd like to suggest you to chech your code to make sure you release the connection as early as possible.
featureReader.Close() should be called as early as possbile when you finished the reader. Folllowing code snippet demonstrate this process:
MgFeatureReader reader = featureService.SelectFeatures( ­);
try
 //¡­.your code here ¡­..
finally
 Reader.close();
Hope this helps some.
Daniel Du
enricapieragostini
I have a problem: when I view web preview from mapserver I get this message "Session has expired or is invalid. Please log in again"
What can I do?
