Hello Guys,
Dose anyone use Mapguide Kaliopa Mobile Viewer as their mobile viewer for their AIMS/Mapguide map server?
The viewer is working quite well on mobile device compared to AIMS original mobile viewer.
The MultiGrid Show.aspx which is used to display the properties (Attributes & Values) of selected features on the map does not recognize the layer attribute visible setting in Autodesk Infrastructure Studio.
It displays all the attributes of the selected features no matter you checked or not checked to display the attributes in Infrastructure Studio.
Dose anyone know how/what should I modify the code to display only the attributes that I would like to show the users? Is there a
"reader.GetProperty.Visible == True" likely code that I can use for filter out the attributes that I don't want to display?
Thank you very much.
Response.Cache.SetCacheability(HttpCacheability.NoCache);
string sessionId = Request["sessionId"];
string mapName = Request["mapName"];
string selection = Request["selection"];
if (string.IsNullOrEmpty(sessionId)) return; //required parameter
if (string.IsNullOrEmpty(mapName)) return; //required parameter
string zoomTempl = ""; //template for button zoom ...
string selectTempl = ""; //template for button select ...
Response.Write("<table class=\"table table-responsive table-bordered table-striped\">");
//Response.Write("<tr class=\"noprint\"><td><hr /></td></tr>");
if (string.IsNullOrEmpty(selection))
//other ways to get selection ...
else
selection = Server.HtmlDecode(selection);
if (!string.IsNullOrEmpty(selection))
MgResourceService resourceSrvc = GetMgResurceService(sessionId);
MgFeatureService featureService = GetMgFeatureService(sessionId);
MgMap map = new MgMap();
map.Open(resourceSrvc, mapName);
MgSelection sel = new MgSelection(map, selection);
foreach (MgLayerBase layer in sel.GetLayers())
Response.Write("<tr><td><b>" + layer.LegendLabel + "</b></td></tr>");
Response.Write(
"<tr><td><table class=\"table table-responsive table-bordered table-striped\" align=\"left\" CELLPADDING=\"2\" CELLSPACING=\"2\">");
try
string filter = sel.GenerateFilter(layer, layer.GetFeatureClassName());
MgResourceIdentifier resId = new MgResourceIdentifier(layer.GetFeatureSourceId());
MgFeatureQueryOptions query = new MgFeatureQueryOptions();
query.SetFilter(filter);
MgDataPropertyDefinition idProperty = GetIdProperty(featureService, layer);
List<string> featIds = new List<string>();
MgFeatureReader reader = featureService.SelectFeatures(resId, layer.GetFeatureClassName(), query);
string geom = layer.GetFeatureGeometryName().ToLower();
Response.Write("<tr><th class=\"header\"></th><th class=\"header\"></th><th class=\"header\"></th>");
for (int i = 0; i < reader.GetPropertyCount(); i++)
if (reader.GetPropertyName(i).ToLower() != geom)
Response.Write("<th valign=\"middle\" class=\"header\">" + reader.GetPropertyName(i) +
"</th>");
Response.Write("</tr>");
Response.Flush();
int autonumber = 1;
while (reader.ReadNext())
string clas = "main";
if (autonumber % 2 == 0) clas = "main2";
Response.Write("<tr onmouseover=\"LineOn(event)\" onmouseout=\"LineOff(event)\">");
Response.Write("<td align=center class=" + clas + "><b>" + autonumber.ToString() +
"</b></td>");
Response.Write("<td align=center class=" + clas + "><b>" + string.Format(zoomTempl, layer.Name, GetPropertyValue(reader, idProperty.Name)) + "</b></td>");
Response.Write("<td align=center class=" + clas + "><b>" + string.Format(selectTempl, layer.Name, GetPropertyValue(reader, idProperty.Name)) + "</b></td>");
autonumber++;
string val = GetPropertyValue(reader, reader.GetPropertyName(i)).ToString();
if ((val.IndexOf("http") != -1 || val.IndexOf("www") != -1) && val.IndexOf("href") == -1)
val = "<a href=\"" + val + "\" target=_blank>" + val + "</a>";
Response.Write("<td align=left class=" + clas + ">" + val.Replace("\\n", "<br />") + "</td>");
Response.Flush();
reader.Close();
reader.Dispose();
catch (Exception)
Response.Write("</table></td></td>");
Response.Write("<tr><td> </td></tr>");
Response.Flush();
Response.Write("</table>");
Solved by reno.sun.gis. Go to Solution.
I found the answer in C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2014\www\mapviewernet\getselectedfeatures.aspx
You will need to add following codes into MultiGrid_Show.aspx to get the layer property mappings.
<script runat="server">
String mapName;
String sessionId;
String locale;
CultureInfo culture;
System.Text.RegularExpressions.Regex regex;
static NameValueCollection GetLayerPropertyMappings(MgResourceService resSvc, MgLayerBase layer)
NameValueCollection mappings = new NameValueCollection();
MgByteReader content = resSvc.GetResourceContent(layer.GetLayerDefinition());
XmlDocument doc = new XmlDocument();
doc.LoadXml(content.ToString());
XmlNodeList propNodes = doc.SelectNodes("//LayerDefinition/VectorLayerDefinition/PropertyMapping");
foreach (XmlNode propNode in propNodes)
String name = propNode["Name"].InnerText;
String value = propNode["Value"].InnerText;
mappings[name] = value;
return mappings;
</script>
Then, you will be able to add only the attributes that you would like to display to your users.
NameValueCollection mappings = GetLayerPropertyMappings(resourceSrvc, layer);
foreach (String key in mappings.Keys)
query.AddFeatureProperty(key);
query.AddFeatureProperty(geom);
