The reason of this problem is that MapGuide must first load the Plug-in,
then it must load
the observer applet. These two actions execute on separate threads. Thus
when
MapGuide has finished loading and tries to fire the onViewChanged event, the
observer applet may not have finished loading. Thus the onViewChanged event
is
not fired. onBusyStateChanged, onViewChanged, and onViewChanging might
not work properly under Netscape as well when the map is first loaded. I
think the only thing you
can do is try to avoid relying on these events when the map is first loaded
in Netscape.
Haiyun Yang
"Meng Li" wrote in message
news:298FD44C80F406684F8C2E6716842A9A@in.WebX.maYIadrTaRb...
> My onMapLoaded event handler Javascript function works properly in IE, but
> not working with Netscape.
> What i am doing is from another web page to activate a MapGuide CFM file
> page with url variables as where clause parameters for the map. I noticed
> that with Netscape, all MapGuide events are not activated after the
initial
> loading of the cfm file in which a MapGuide map file is embeded. Only
after
> the fist load and i click on right-click Reload function that gives me
what
> are transferred and i wanted. No problem of the events during the first
load
> for internet explorer, why this difference?
> what is a workaround to get rid of this problem? just reload the map
again?
> Thanks
> Meng Li
