I have a serious problem with installation of MapGuide Enterprise 2011 x64 on Windows Server 2008 x64 with IIS 7.
Short description of problem:
A. Installation in evaluation mode - everything works OK.
B. Installation in license mode - problems 😞
1. Verifying the Configuration - only testing the site administrator works. For other tests server issue mesage "Invalide license".
2. Firewall is not a problem (no change with turned off) - pport 2080 and 27000 available.
3. License manager working correctly but obviously can't connect Mapguide server (or vice versa)
Status
Flexible License Manager status on Wed 6/23/2010 23:04
[Detecting lmgrd processes...]
License server status: 27000@atlas
License file(s) on atlas: C:\Program Files\Autodesk Network License Manager\autocad.lic:
atlas: license server UP (MASTER) v11.7
Vendor daemon status (on atlas):
adskflex: UP v11.7
Feature usage info:
Users of 85552MAPGE_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Bundled installation gave the same result - not working,
There are no other flexnet license managers installed on server.
Searching the forums didn't find help fo my problem.
Thank you for any advise.
Had the same problem. Take a look here;
http://mapguide.wordpress.com/2010/06/07/mapguide-2011-on-windows-server-2008-r2-64bit-and-iis-7-5/
you need to download ipv6 support from autodesk then unzip. after that rplace all the file in current license. Files need t replace lmutil, adskflex, lmgrd and lm tools.
