Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Mapguide and DWG
1 REPLY 1
740 Views, 1 Reply
Mapguide and DWG
I have previously posted to this group stating a problem using DWG with
Studio. I still have a problem with service pack 1.
If I try to author DWG files I get a DBX CAS 4 Error. Then a dialog saying
the dwg file could not be read.
If I try to author DWF I get an error that says "Attempted to read or write
protected memory. This is often an indication that other memory is
corrupt"
All other authoring seems to work.
I was at a client office yesterday and they have Studio installed there and
when we tried to Author a dwf and a dwg file they got the exact same errors.
My machine and their machines have Map 2007, Studio 2007 and Mapguide Open
Source installed. Both running XP Pro.
I have tried to uninstall Map 2007 and the author. Reboot then reinstall
the author and it still gives the same errors.
The DWG files work fine in the author on a Server 2003 machine that is
running MapGuide Open Source but no Map 2007.
Help.
1 REPLY 1
Sorry,
I have figured out that the DWF problem is that I was trying to use 3d DWF
files. Studio cannot handle 3d dwf.
Still a problem with DWG.
"gom" wrote in message news:5387705@discussion.autodesk.com...
corrupt"
Help.
