I have run MapGuide 6.5 and ArcIMS on the same server in the past without a
problem. I do not anticipate that there would be a problem with MapGuide
Enterprise and ArcIMS on the server, either. If you use the Java web
extensions for MapGuide Enterprise, I suppose that there might be a
potential port conflict with your Java servlet application, but that could
be easily worked around.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5268998@discussion.autodesk.com...
I was wondering if anyone out there has any experience with loading ArcIMS
and Autodesk Mapguide on the same server? Our organization currently has a
web server that is running ArcIMS. Our IMS administrator is interested in
comparing IMS with Mapguide to determine which is best suited for his needs.
To do that, obviously, we need to load Mapguide somewhere, and we were
curious if anyone has seen any conflicts between the two applications when
loaded on the same server.
Thanks for the help.
Sincerely,
Ross Rebich
Technical Support Analyst
Idaho Power Company
Boise, ID
