Infrastructure Map Server Developer
Valued Mentor
74 Kudos
Post 1 of 5
MapGuide (AIMS) layer definition to AutoCAD Map?
1502 Views, 4 Replies
02-29-2012 02:34 PM
Hi all,
has anyone come across a routine to convert the MapGuide Layer definition into a Map 3D layer definition  *.layer (or at least part-way)
I have 2,000 layers Authored in AIMS that point to SQL Server that I would love to view in Map 3D without having to re-author all 2,000.
Anyone have any ideas?  Cut and paste 2,000 files in notepad?
gordon
ADN Support Specialist
17 Kudos
Post 2 of 5
Re: MapGuide (AIMS) layer definition to AutoCAD Map?
07-30-2012 01:48 AM in reply to: gluckett
If I recall correctly, layder definition is a subset of *.layer file, so it should be possible to convert layer definition to layer file programmatically.
I will check with development team and let you if I have further information to share.
Daniel Du
Developer Technical Services
Autodesk Developer Network
Valued Mentor
74 Kudos
Post 3 of 5
07-30-2012 10:59 AM in reply to: gluckett
Thanks Daniel, it would be great to modify the Layer XML in AIMS/MapGuide to correspond to the Layer XML in AutoCAD Map 3D!
Valued Mentor
24 Kudos
Post 4 of 5
07-31-2012 08:38 PM in reply to: gluckett
Some published specs on the .layer format would be nice.
All I could get out of it is that it's some mish-mash of a Layer Definition and a Feature Source in a RDF document shell with some inline binary blobs for storing any configuration documents.
- Jackie
17 Kudos
Post 5 of 5
08-09-2012 12:11 AM in reply to: jackie.ng
BTW, it is possible to get/set the XML representation of layer definition in AIMS and Map 3D using MgResourceService.
So we can retrieve the layer definition in AIMS and put it back into Map 3D with resource service.
Does this help?
Daniel Du
