Infrastructure Map Server General Discussion
Member
gm72
Message 1 of 4 (768 Views)
Mapguide 6.5 Modifying MWF Files
768 Views, 3 Replies
12-08-2011 12:47 PM
I am looking for a way to programatically modify mwf files. Specifically, I want to be able to load a map and change the Map Server Agent URL value on all of my layers within the MWF file.
I have been looking at the MGMapLayerSetup.getServerUrl method within the API but I'm not sure and cannot find any examples of how to implement this within a .NET application.
Are there any examples that you guys know of that can help me access this setting and modify the properties?
Thanks.
George
Valued Mentor
jackie.ng
Message 2 of 4 (766 Views)
Re: Mapguide 6.5 Modifying MWF Files
12-08-2011 05:40 PM in reply to: gm72
Save them as MWX files (via Author or Dynamic Authoring Toolkit) and edit the XML content using your XML document API of choice.
- Jackie
Member
gm72
Message 3 of 4 (758 Views)
12-09-2011 09:46 AM in reply to: jackie.ng
Thanks for the reply. Is the Dynamic Authoring Toolkit on the CD for 6.5 or where is the best place I can get hold of the installation for this?
I assumed that it should be converted to mwx first, I have been converting manually in the past, so this helps clear up the confusion. I wanted to make sure there was not a direct way to interface to the map using the API.
Valued Mentor
jackie.ng
Message 4 of 4 (752 Views)
12-11-2011 05:29 PM in reply to: gm72
