Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Mapguide 2012, IIS on Win Server 2008 R2 x64
4 REPLIES 4
ced_abitat
2167 Views, 4 Replies
Hi all,
  I have install Infrastructure MapServer 2012 (64 bit) on Windows Server 2008 R2 64 bit. I have choose IIS as Web Server and PHP as API.
I wuold like to connect with Microsoft SQL Server 2008 but on PHP extension there isn't any extension for MSSQL. I read that PHP 5.3 don't have native extension for MSSQL. So I download Sql Server driver for PHP 2.0 and add extension on PHP.INI.
Now when I start a phpinfo page I get a error on php-cgi.exe: The FastCGI process exited unexpectedly. The error code is 0x000000ff
Can you help me?
Regards
Matteo
4 REPLIES 4
gluckett
in reply to: ced_abitat
Just use ADO
  $connstr="PROVIDER=SQLOLEDB;SERVER=localhost\\SQLEXPRESS;UID=sa;PWD=password;DATABASE=MAIN;
$conn = new COM("ADODB.Connection",NULL,1252);
 $conn->Open($connstr);
this works with IIS and Windows Server 2008 R2.
gordon
Daniel.Du
You can use OSGeo FDO provide for SQL Server Spatial, which is a buit-in provider of Infrastructure Map Server 2012.
Daniel Du
Developer Technical Services
Autodesk Developer Network
swimming123
in reply to: Daniel.Du
How can I connect to PostGIS for Autodesk Infrastructure Map Server2012? Thank you.
Daniel.Du
OSGeo FDO Provider for Postgre/SQL/PostGIS is one of built-in providers, you can connect to PostGIS with this provider in Infrastructure Studio by adding a new "Data Connection".
Daniel Du
