Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
MapAgent Test Failed But Shows as Running
0 REPLIES 0
Message 1 of 1
cbuchinski
225 Views, 0 Replies
Ok, i have installed MapGuide Open Source 2.0 and have installed the .php web extensions.
I can log into the administrator site without an issue, i can run the webserver extensions test without an isssue. But when i try to run the MapAgent test i get "Page cannot be found" Error 404. When i log in to the Administrator Site, it show the "server" is running. What should be the first thing's i should check out?
0 REPLIES 0
