We have set up MapGuide Enterprise 2007 on two new Windows Server 2003 with
the SHEBOYGAN dataset and dotnet sample application installed. Testing on
the configuration of the MGE server shows no problem.
However, when opening the ajaxviewersample.aspx on my XP with IE, the map
didn't show in the first time loading, only after the second time refresh
(either through the browser Refresh button or through one Viewer toolbar
button like Pan which triggers a refresh), the map showed. This refresh
problem happens constantly for all actions such as Find Parcels/Address
functions, i.e. only after every second time run of a function, the map
shows, the first time run of it always ends up with a blank background map.
No error messages.
when opening the dwfviewersample.aspx, the same refresh problem occurs but
in some cases, this error message occurred from Find Parcels/Addresses:
MapGuide server error: status code 559 MgNullReferenceException. Also
sometimes this error from an initial loading:
Any help on this is much appreciated.
Meng
