Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Map Pane Does Not Show Map
1 REPLY 1
Jembut_Berseri
279 Views, 1 Reply
Hi folks,
I found a problem on map pane. At least once in a day i have to restart my mgserver because it can not show up map at the map pane. The ajax indicator run, all other panes are shown. No error message are thrown, all service run properly. I'm using mge 2009 with IIS
Anyone know how to solve this problem
1 REPLY 1
In addition i would like to inform that the selection is work. If i make a click in the map pane, the selection properties is updated, but the map pane is blank and ajax indicator blinking all the time..
